Hi Guys,
I've got an Mira Azura 9.8kw electric shower that has developed a fault.
Currently as soon as I turn the shower on the light in the button turns straight off and I get a short 3 second burst of water and it then immediately turns stops. If I play around with the button sometimes the light will flicker for a bit and if I hold the button down the shower seems to keep running.
Any thoughts? Flow seems the same as ever and when it's running the thermostat seems to work fine, maybe the shower is a little cooler tho.
It also 'might' be a bit better on full cold, although I can't really find a repeatable pattern to it.
Thanks for any help! Having a heavily pregnant women denied a shower on a Sunday morning is not a good thing!
