Shower part help
30 Dec 2010
Over here
Dear all,
The shower holder holder wotsit was sliding down a bit so I moved it up the guide rail to the desired height, turned the dial and it just snapped off. Now, aside from not knowing how to get it off for when/if I do find a replacement, I do not know what to ask for in a plumbing shop or search for online.
Any help would be greatly appreciated. AS you can see the showerhead is still stable but it's stuck at the bottom as I cannot tighten the wotsit to move it up.
It's part of the shower riser kit, assuming what you have there is plastic (as it snapped) it will probably be easier/cheaper to just by a whole new riser kit (which includes a shower hose/head), can be had for £15-30.
Excellent, I found plenty of these once I had the right search phrase (riser kit). Many thanks for your help, I was anticipating much higher cost.
