Shower thermostat/feed issue
23 Nov 2019
Any plumbers on here? I'm wondering what might be causing my shower not to go properly cold:
I have a shower powered by a pump unit under the bath that goes to a Grohe mixer unit with a thermostat and from there out to the shower/bath depening on which outlet you choose.
I cannot get the thing cold. I've just adjusted the thermostat which was previously set wrong so the stop now sits at 38C as it should but the coldest setting still doesn't go any colder than before.
The hottest it goes is 46-47C the coldest it goes is 24C. Even if I take the stop out completely and turn the valve all the way it still sits at 23.5C.
The temp out of the adjacent sink cold tap is 12.5C.
If I turn the pump off and run the shower the lowest temp is still 24C but the pressure is just much lower.
Bathroom sink tap flow rate 11 litres / min.
With the pump off the bath flow rate is only 5 litres / min out of the bath tap.
The mixer unit is at roughly the same height as the sink, and the bath tap much lower down so I would have expected similar pressures, unless the pump is adding resistance in its off-state.
I've checked the hoses and feeds and all the isolators are set to fully-open.
Does anyone know what might be causing this and what I could do to adjust it?
