- 27 Sep 2004
- Norfolk
Hiya
OK, i hope at least one of you will be able to help me!
I'm looking to build a computer to be used as a main computer, but essentially as central point for my home entertainment (like, a central system to connect my HD TV (HDMI), surround sound, and to be able to upscale dvd's for my HDTV.)
The PC will not be used for gaming, but will need to be comfortable with a fair amount of multi-tasking, and the more hard drive space the better! (I already have a 250GB & 200GB hd's, but will need more!) Also the PC won't be overclocked.
It'll need to include a remote control, flat screen monitor, vista home premium 32bit(?), case, motherboard, cpu, memory... basically everything!
My budget is around £800, but can be adjusted if need be.
Thanks for any help you can offer :]
