i dont know exactly how many hours, but last night i left my computer on and woke up to it being off(was like 4ish hours between the point of sleep and wake up), figured power went off, but everything else in the room(fans/lamps) still running, it wasnt till i turned the computer back on to realise it shut off on its own as google tabs had to be restored, then.......
from somewhere between 5:30-6am when i woke and turning computer on till before 11 when i went down stairs the computer was running fine, didnt even use it, so left it on, then about 10 minutes ago i came back upstairs to use it and it was off, same story with the shutdown and restore brower.....
its a very warm day, has been last couple days here in devon, but its not hot in the house and i had 1 side panel off my case which i havent put on since the rebuild, so i can keep eye on things as sometimes the usb ports on case act funny, so its not like theres bad ventilation especially with 3 fans, so i have no idea whats going on
, never had heat issues with this system before and could run pretty much 24/7 prior before yesterday.
does anyones have any solutions i could try?
barely any dust in the case and nowhere near enough dust on heatsinks to cause blockage, my power supply seems to be running fine too, there is just nothing evident to suggest hardware faults, hell if the paste on the cpu dried it wouldve burnt up long before the first hour or 2 im sure.
