Shutdown - Not shutting down ?
Man of Honour
16 Mar 2005
Clevedon , Bristol
Any advice here ?
After clicking shutdown in Windows, windows shuts it self down - Good :)
But, the computer will not shutdown - i.e all system fans,pumps,lights etc. keep running - Not good :(
Faulty mobo ?
Cheers for any help.
Or it could be a driver problem. I had the same with my Windows 7 x64, would stall on shutdown for about 15mins then throw a BSOD at me.
Has it always done this since install or just started happening?
Also do you have another OS on a bootable DVD/memory stick (Knoppix, Windows PE etc) that you can test to see if it has the same problem to try to isolate whether its driver related?
