Shutdown Timer
20 Feb 2004
Hondon de las Nieves, Spain
Similar to with Tv's etc where you can get it to auto turn off after 30mins or so.
Is there anything you can set on a pc to do this other than the usual power saving options? Or going into Standby etc
Cheers
you can use windows build in shutdown feature, but thats a bit complicated and only runs in dos, on the other hand there is this program which i love Shutdown Scheduler which has lots of functionality and can do basically anything from shutdown and stand by to just switching the monitor off so you can leave the pc downloading :)
