Dont seem to have 5.1 out of my SN68PTG5 on my DVDs on windows 7
Is it a driver issue? using the stock drivers that come with windows 7, can do the speaker config test and all channels work fine so have the 3 connectors in the right holes (colour coded anyway)
Really want to get dolby digital then can do the next step of putting sky HD through it with the optical upgrade you can buy.
