*** *** Shuttle 'D'Vo' D10 Touch Screen Aluminium Barebones System - Intel Core 2 Duo @ £329.99 inc VAT *** ***
The D10 comes with an embedded 7-inch touch panel in a creative media centre gadget which delivers various applications with the easiest operation. Through surveillance software and equipment, it gives the convenient way to secure your home. D10 is designed as standalone media center to experience the digital entertainment just with a remote control directly.
The embedded 7-inch display with touch screen technology delivers the simplest operation by giving the multiple functions beyond your imagination. The high-tech design lets you control multimedia functions from music, movies, video playing to internet surfing with one easy click.
Dual View technology offers convenient visual experience and better work efficiency. Working with 2 monitors means you are no longer confined to a single monitor, spreading your work or entertainment over dual displays. No more minimizing display, you can see clearer and work more efficiently and effectively.
- Shuttle Form Factor 305(L)x200(W)x180(H) mm
- Shuttle “G7” Chassis
- Intel Core 2 Duo CPU Support
- Intel G31 + ICH7
- Dual channel DDR2 667/800
- 2 x DIMM slots, 2GB per DIMM (Max 4GB) VGA
- Intel GMA X3100 256bit 3D engine with a powerful 400MHz core
- DirectX 9 support
- Dynamic Video Memory Technology(DVMT)3.0 supports up to 384MB of Video memory
- Realtek ALC662
- Supports Analog 5.1 channel output
- Marvell 88E8056
- IEEE 802.3u 1000Base-T compliant
- 10Mb/s, 100Mb/s and 1000Mb/s operation
- Wake-On-LAN support
- 1* UltraDMA 100 IDE channel connector
- 2* On board SATA connectors
- 100W
- Input:100- 240V AC
- 2* 3.5” bay
- 1* 5.25” bay
- 1* Power-on button
- 1* Power indicator - blue
- 1* HDD indicator – orange
- 3* OSD button
- 1* 7” LCD touch panel
Only £329.99 inc VAT.
ORDER NOW
- Intel G31 + ICH7
- DirectX 9 support
- Realtek ALC662
- Marvell 88E8056
- 100W
- 2* 3.5” bay
- 1* 5.25” bay
- 3* OSD button
ORDER NOW
