Shuttle graphics Solution
23 Nov 2004
UK
Adding another HTPC to the house for the bedroom.Need a decent-ish Graphics card for it as i would like the odd game of BF2.
Budget would be about £100-£130 and not a FANBOY so either Nvidia or Radeon.Would also consider 2nd hand but would like to know what would fit plus be quiet enough for my needs.
Any thoughts?
Edit:- it's a PCI-E Shuttle.
better to tell us the Shuttle model, as psu wattage and card location may be a factor, but I'd hazard a guess the x1950 may be high on the list at that price point :)
You're a bit pushed with the ST20G5 as it will only take single slot coolers unlike the newer Shuttle P-chasis.
The Sapphire ATI Radeon X1950 Pro 256MB GDDR3 HDTV/Dual DVI (PCI-Express) or the Connect3D ATI Radeon X1950 Pro 256MB GDDR3 HDTV/Dual DVI (PCI-Express)would do nicely.
A few reviews have mentioned issues with the ST20G5 and non-ATI cards, so the X1950Pro would definately be a good choice, and for £120 inc VAT you can't go wrong. Its a shame an arctic silencer won't fit too as the HIS comes with one ready fitted for £125.
Thanks for deleting the other thread and for answering here.Do either of the cards you mention support HDTV?Have a 32" Samsung LCD that this will be plugging into.
CS||nuTs said:
That looks like a cracking deal. http://www.overclockers.co.uk/showproduct.php?prodid=GX-134-SP
Been out of the "leading edge" graphics market for quite sometime,well in PC terms anyway.Last decent card i had was a X1900XT.Are these cards anywhere near the performance of that as they seem remarkably cheap?
Its a little bit slower than the X1900XT but not a lot, and the price is fantastic :)
They're well loved cards:
http://forums.overclockers.co.uk/showthread.php?t=17668879
Yup its single slot, think its slower, have a look at some of the reviews in the X1950Pro thread see if you can find a comparison :)
If you look on Tomshardware interactive comparison chart the X1950Pro beats it soundly across the board.
dave - the X1950 series is slower than a X1900XT?
Im contemplating putting My X1900 (master card) into a 37P, as an HTPC build, along side a E4300 and 2gb 6400 DDR2, hopefully this should be a good combo then
A true shuttle convert after having a 25P (still in everyday use) for the last year or so
From what I understand though the X1950 PRO has much lower power consumption than the X1900 XT, so less heat, less noise and less stress on our PS's.
thank you :D - hadnt seen any X1950 XT's,
After having a quick look at the relevant page am I right in thinking there are no 512MB X1950 XT's (all 512MB cards seem to be Pro or XT-X?)
I have seen 1950 XT's with 512mb knocking about on the net but there does seem to be a price hike from bog standard XT's.
Certainly OCUK don't seem to have any.
You could always get a 1950 PRO and then Crossfire it when the prices tumble.
