Shuttle help
16 Jun 2007
London
right so i sold my full tower watercooled PC for somethign more accessable, ie a shuttle.
i jsut need to know is there a shuttle that will fit a GTS250/ 4850 and a cooler for the E5200 than can OC to atleast 3GHz?
do the shuttles OC?
Yes, yes and yes.
The Shuttle power supplies are good, I'd probably use a SX48P2 as a starter for a performance system. Graphics card wise, check out the dimensions first but can't see a problem, planning on a 4850 or 4870 in my old SD37P2 any time soon.
They do overclock, my E6700 clocks to 3.6Ghz and maybe I can squeeze a bit more out of it when I've invested in some decent memory.
much <3.
mmm will a 4870/GTX260 fit in the SX48P2-E?
if not a GTS250/4850 is enough, all i play is cod4 :D
what CPU cooler would one recommend?
How long is a 4870 ?
The old 8800GTX's used to fit.
The Shuttles come complete with a nice cooler/heatsink. They are surprisingly good with a fan on either side on the P2 versions. They are fairly tunable too, there are options for fan speed in the Bios and a downloadable utility from the Shuttle website will allow fine tuning from the desktop. On mine, a SD37P2 which is now a deleted model, the heatsink has different spacings to Intels, so you have no choice but to use the standard heatsink, they are good though.
