Shuttle motherboard to atx case
27 Oct 2002
Liverpool, England
Hi everybody does anyone know if you can put a shuttle motherboard into a standard atx case cos I have just bought a graphics card and its to big for my case but i dont wanna take it back so just wondering if i could put all my stuff in a new case. The board is a FN45 cheers...
That would be like putting a doormouse in a XXXL pair of pants!
There are four problems I can see with putting a shuttle motherboard in an ATX case.
1) Mounting the motherboard
The shuttle motherboard is a size that only shuttle uses, so on an atx case the mounting screw holes wont be in the right place. This can be solved if you measure up where they need to be and drill your own.
2) The CPU cooler
Obviously shuttles come with custom coolers, so fitting a different one that will work inside an atx case could be tricky.
3) The power supply
Again, not a standard size, but not impossible to attach somewhere.
4) The back pannel connectors
These wont match up with the back of the case, but you could feed the wires through the hole at the back to connect them. This would mean that you have to open the case every time you want to unplug something. The other bad thing is the PCI slots wont match up, so suporting the weight of a huge graphics card could prove to be a pain.
So to sum it all up, the short answer is yes but it would be really really complicated, so probably not worth the hassle.
PK!
If you're going to go through the hassle of modding a case to fit in a shuttle board, you might as well go all the way and mod it into something interesting like an ammo box ;)
Now thats an interesting idea.....
If only I had a shuttle motherboard...
and an ammo case....
and all the other bits I'd need.....
D'oh! :(
PK!
