Shuttle PC specs?
This has DVI (PC) and HDMI (TV) out, just add in PCI-E TV card and youre good to go
It's a lovely little case. This is a decent motherboard to build from. :)
Edit: It's the same motherboard as in the spec you've been given above. That looks like a good spec to go for. Depends wether you'd want to add a graphics card too. If you do go down that route you'd need to look for the shorter models, although finding them can be a pain.
Good luck and lets see some pics when you get all of the hardware. :)
I have a E6300/E6400 spare so i could just use 1 of those.
Thanks for the input. Might not need a bluray player tho - this isn't anything fancy!
