shuttle prob please help!!! driving me mad!
31 Dec 2002
on my PC
my pc just reboots for no reason? you can hear the hdd turn off, then once it boots up again it reads the hdd as loads of funny letters. so i though oh right the hdd is dead ill just go buy a new one, got a wd 250gb but it still does it with this one just comes up with funny letters??? i have tryed diff ram and still does it??? please help
sorry if u cant get the wording on this very hung over
Well you've isolated the hdd and the ram, so i would say the board is the next likely culprit.
You could try installing a 2nd clean copy of windows just to make sure its a hardware problem. You could also try a bios update.
yea tryed reinstalling windows on both copys still doing it must be mobo then? cant find a bios update for the fn45 shuttle
the cable looks fine did the same on both leads. has not done it since bios change so fingers crossed!
My initial thoughts were thermal cutout cos of the cpu over heating but that would cause it to just turn off.
Just incase check there isnt a red led coming on when it reboots.
it was the ide cable, thanks for that one would have never though of that! great help saved me pennys
