Shuttle SK21G - What is it capable of?
1 Apr 2003
London
Evening all,
Im trying to give a friends Shuttle SK21G a bit of a revamp. This is what is in it at the moment:
AMD Sempron 2800+ (S754)
1Gb PC3200 Geil Value
256mb 7600GS AGP
160gb WD HD
DVD/RW
Wifi PCI card
A few extras (freeview TV stick, Xbox 360 pad) running off the USB 2.0 plugs.
200w Shuttle PSU
My plan is to replace the 2800+ with a A64 3400+ and then change the graphics card to something a bit better than the 7600GS, my question is - what would this machine be capable of running considering the small PSU? I assume the 1950pro is out of the question? What would be the best I could go for?
Thanks in advance.
i'd have thought an x1950pro should work fine, espesh considering it uses less power than a normal x1900 :)
shuttle PSU's are v.good quality and run most things you can throw at it. though may be worth checking what psu is in it?
achme psu's tend to be the ones that will run most things
enhance ones are a bit lacking and generally wont even run a 9800pro. but i dont know if shuttle still use these??
