Shuttle SN25P
9 Sep 2009
I'm currently having trouble finding a graphics card that will fit this case, the old graphics card is almost dead, just looking if anyone has any suggestions.
the newer series fans are way too big for this case and also too long i believe, it doesnt have to be amazing and the cheaper the better as its now just a family PC and pretty much all they do on it is browse the internet and play windows games etc.
has a PCI-e slotx16 i believe, dont really know much more about it as its had this graphics card in it for a good 5 years of heavy usage.
Thanks
Phil
Almost any GPU card with a single slot cooler should fit....
What type of price range were you looking at spending for a new GPU card ??
errr well around £50-60 maximum, i dont mind ati or nvidia, as i said is pretty much for browsing and simple windows games etc.
thanks, ordering it now~
I would have paid a little bit more and got a 4670 but that card is good for the price.
A couple of years ago I used to have a SN25P and ran a X1800XT in it, so a dual slot cooler card is possible with a bit of fiddling about.
