My server is an old SN27p2, the bearings have gone in one of the system fans. This product is no doubt discontinued.
The system fan is two 60mm fans, both connected to the same 4pin header.
Any suggestion on a replacement? Best I can find is 2 60mm fans (3 pin cable), using a y splitter cable. Obviously if I have to settle for 3 pin I will loose the speed control and RPM status.
