- 6 Oct 2005
Hi,
I'm having to use my old Shuttle system cos my 'proper' pc's case is currently RMA'd to OCUK
Unfortunately my bad luck hasn't stopped there, cos the Shuttle is playing up a bit too!
Current config:
Shuttle SN41G2 (v1 or 2, probably v1)
Athlon 2500XP
2x512mb Corsair Value Select DDR400
Radeon 9700 128mb
120gb WD hard drive
Samsung DVD
Software / drivers:
Win XP Pro SP2
Latest NForce drivers
Cat 7.2 (but no CCC cos of the installer bug)
Ati Tools
Overclocking:
FSB at 166mhz, so cpu not overclocked.
I did have the memory running at 400mhz, but I've tried running it in-sync witht the processor at 333
Graphics card at stock.
I've recently reseated the heatsink with a fresh application of Arctic Silver, and I've seen no CPU Overheat warning light on the motherboard.
Symptoms:
System sometimes operates completely normally, even during intensive Day Of Defeat : Source sessions (highly stresses cpu and gpu)
Othertimes.. it will restart even during the bios startup.
I've had it run normally with the case on, and I've had it do reboots with the case off so I don't *think* it's an overheating issue. It reboots when starting Windows, idling at desktop, during internet browsing, or mid-game.
When the system restarts often the BIOS screen appears slightly corrupted - small lines appearing randomly across the screen, parts of text missing. It still seems to work ok. Obviously that looks like the graphics card might be playing up.
Tonight has been particularly odd - I almost gave up trying to get it to run for more than 2 minutes, then gave it 'one for luck' and it's run fine ever since (for 4 hours of full-time DOD:S, with TeamSpeak running too)
The graphics corruption made me think about the Radeon card, but the air coming off that is cool, and it happens even during the BIOS start up, so surely that rules out the card, it's drivers, and the motherboard drivers for that matter.
But there is one thing I noticed when I checked the BIOS setup: I went to the PC Health Status page, and noticed the PSU voltages aren't on-spec for one setting: there is a "-12v" monitor that is reporting "(-)13.46v" which seems an awful long way from -12v! The "12v" reading was normal (can't remember exactly .. 12.2v?), as was the 5v (5.1v?)
Is that likely to be my problem? Do I 'just' need a new PSU?
Any thoughts would be gratefully received!
edit: I've changed WinXP so it won't auto-restart - so I can catch any BSOD messages. I'll post 'em when I get 'em!
Unfortunately my bad luck hasn't stopped there, cos the Shuttle is playing up a bit too!Current config:
Athlon 2500XP
Radeon 9700 128mb
120gb WD hard drive
Samsung DVD
Software / drivers:
Win XP Pro SP2
Ati Tools
Overclocking:
Symptoms:
. In this case however, due to the length of time you've been able to play games, it doesnt sound like a temperature issue.
