- 8 Apr 2004
Hi, I currently have the above barebones with an Athlon XP-M [email protected], 2x512MB PC3200 DDR RAM, Maxtor DM9 60GB ATA133 HDD and Radeon 9700Pro 128MB card. It was all working fine before I attempted to replace a few components:
- switched the 80mm fan (which was a Silenx I had mounted externally, with grill removed of course) back to a 80-120mm fan adapter+Akasa Amber 120mm fan, which I used before with no problems
- wiped off and reapplied Arctic Silver 5 to my CPU, seeing as I had to remove the heatpipe system anyways to install the 80-120mm fan adapter
- replaced my Maxtor DM9 60GB with a Maxtor DM10 250GB HDD
- replaced both flat IDE cables with rounded ones
- replaced the stock HSF with an Arctic Cooler VGA Silencer Version 2 on the Radeon
When I had this all fitted in, I pressed the power button but nothing comes up on the monitor, although all the fans spin as expected. Resetted the CMOS a few times but has made no difference. Tried reseating EVERYTHING like a gazillion times and again, nothing. Tested each individual component in another PC and they were fine.
The Shuttle was perfectly fine before I started replacing things. I can't exactly put things back to exactly as before now, especially the stock HSF for the Radeon, and anyways, all the components work fine individually. Hope the Shuttle hasn't just gone kaput like that, because it cost me £150 over 2 years ago, and I'm not even sure whether the XP-M 2500+ is working too, and that cost me £70 from OcUK! Anyone have any ideas about what else I could try out? I'm gonna try reseating everything again tomorrow but may have to plan for a new motherboard, CPU, case and PSU
If it was just the Shuttle that went bang and the CPU was perfectly fine, I guess I could just buy a cheap Socket A mobo and case for the time being...
