6 Jun 2007 at 23:55 #1 Apatche64 Apatche64 Associate Joined 8 Dec 2003 Posts 697 Location alsager, near crewe anyone had probs with vista 64bit ultimate with a shuttle sn85g4? 32bit works fine ...
7 Jun 2007 at 00:29 #2 Tute Tute Soldato Joined 24 Jul 2004 Posts 22,593 Location Devon, UK Need a little bit more information than that. What kind of problems? And what spec inside the Shuttle?
7 Jun 2007 at 08:26 #3 Apatche64 Apatche64 Associate OP Joined 8 Dec 2003 Posts 697 Location alsager, near crewe usb keyboard and mouse not working... spec is: sn85g4 3200+ a64 2gb geil pc3200 x800 pro hitachi 160gb hd... wondered if it might be it not supporting 64bit vista or something? cheers
7 Jun 2007 at 10:04 #4 cokecan cokecan Soldato Joined 4 Jan 2004 Posts 7,815 Location Nottingham ran the 64bit RC2 on my SN85G4V3 with no problems. also had/have a similar spec to you 3400+ clawhammer 2gb mem 9800xt (used to have x800pro when i had vista on)
7 Jun 2007 at 10:07 #5 Apatche64 Apatche64 Associate OP Joined 8 Dec 2003 Posts 697 Location alsager, near crewe do you think mine being version 1 has something to do with it?
7 Jun 2007 at 10:44 #6 cokecan cokecan Soldato Joined 4 Jan 2004 Posts 7,815 Location Nottingham dont think so, it should work regardless what exactly is the problem here?
7 Jun 2007 at 12:31 #7 Tute Tute Soldato Joined 24 Jul 2004 Posts 22,593 Location Devon, UK Have you tried different USB ports? Tried booting into Vista and then swapping it into a different port? And are you sure the keyboard and mouse actually work?
