Shuttle sp35p2 issues with 8GB corsair ram
3 Jan 2009
Hi
I have installed 8GB corsair xms pc6400 800mhz ram (4 x 2GB sticks) in my sp35p2(v2) and when i get to the point installing vista where it says vista is checking your ocmputers performance it bluescreens. Usually it says hardware error, system halted and after that it gets random bluescreens i.e. ntfs.sys.
Can anyone running 8GB ram particualrly corsair advise me of the settings i need to do in the bios. So far i have been trying to increase the nb voltage to 1.4, the ddr voltage to 1.9v, setting the memory timings manually to what it says on the sticks etc. Also i have flashed to the latest bios.
At the moment i am not sure whether it is the ram at fault (should i get another manufacturer) or the settings in the bios.
any help would be great
