Shuttle ST20G5 HSF
23 Nov 2004
UK
Anyone know if there is a after-market cooler for these? Got a problem with temps on mine and would like to try another cooler for reference.
ST20G5 has standard fittings around the CPU, i've got a zalman reserator and the water block came with te correct fittings. Only (major!) problem was i had to take the whole blummin' thing apart unscrew the mobo to get to the underside of the CPU socket, so it's a nightware to set up originally but once the "nipples" are installed, its easy :)
