Shuttle watercooling revisted
18 Oct 2002
Hook
Did post years ago about watercooling my glamor xpc, but never had much response so gonna try again.
Well first of all my amd board gave up so replaced with an sg31 and the holes are still big, well the AMD cooler does not fit anyway as the pipes are two long, however the heat plate does line up so thinking of cutting the pipes off then the middle out of it leaving a square hole and slipping an all in one 120mm system into the hole, due to the existing 80mm using a 80-120mm fan adaptor, thinking of buying the kraken x31 or the coolermaster seiden.
The CPU is a 2.53 core 2 duo which will be run on as low volts as I can get away with.
Main object of the game is as silent as possible performance is not that important as will just be a media player, I would imagine an all in one would be man enough to cool it.
Any thoughts. I am not new to watercooling as I built my gaming rig years ago with the bests parts available at the time and it is still running sweet not that I use it loads these days.
With abit of modding here and there I found a way of doing it, only testing in bios at moment until fan adaptor come but really low temps, not that I'm fussed as object of the game is silence
