Shuttle XPC SD37P2 + QX6700
9 Jan 2007
Hi
For info, just set one of these up in a shuttle for a rendering app.
Here are the results
SPEC
Shuttle SD37P2
QX6700
Zalman ZM-STG1 thermal compound
2GB DDR II
7600 GT
150GB Raptor
DVD writer
Temps under load - all cores
Standard Clock Speed
Smart Fan on
Sys 38
CPU 68
Cores 78 - 82
Running near silent
Fixed temp control at 60Deg
Sys 38
CPU 59
Cores 68-71
Moderate sound.
Fixed temp control at 62Deg
Sys 38
CPU 62
Cores 70-74
About the level of sound I would be happy with.
All fans max speed.
SYS 35
CPU 54
Core 63-67
High level of sound
nice to see a quad core workin in a 37P :)
dunno how good that zalman paste is but i'd be tempted to put some AS5 on instead, may well drop the temp a few degrees
how quick do you find the system and what rendering program's do you use?
Hi
I read a few reviews on the Zalman past and it seems to have similar peformance to AS5. I find it much easier to apply. Another QX6700 I set up with a Tuniq tower and the Zalman stuff runs at 50 deg full load which I dont think is bad.
The system is very quick :D
Render in Carera, Bryce, Poser and Truespace.
