- 3 Mar 2009
http://www.overclockers.co.uk/showproduct.php?prodid=FS-128-SH&groupid=701&catid=110&subcat=343
Im thinking of getting 1 of these, and i thought id just check to make sure everything works as i think it does before i order.
As far as i know, all i need with this is a CPU, RAM, GPU, HDD and DVD Drive and i can slap em all in and be good to go. I already have these (Q6600, 4GB DDR2, 4870 1GB, 500GB HDD and a normal DVD writer drive). So heres the thing -
I assume it uses its own type of cooling system, i just need to put the CPU in and use whatever the Shuttle uses to cool it.
The PSU, will it be enough to power everything ? It says its 400w, and does it provide 2 PCIe connectors or do i need a molex converter thing ?
Will my GPU even fit in ? Its this exact 1 -
Would it be safer for power/space/heat reasons to get a smaller, single slot GPU (4850) ?
Anybody currently running 1 of these ? Have any pics spare so i can see how well your stuff packs into it ?
Thanks in advance if you can help
