Shuttle XPC SX48P2-Deluxe Barebone System
Man of Honour
18 Oct 2002
West Coast of Scotland
Expensive yes but is it worth it? I'm considering selling my Inspiron system here and upgrading to one of these. I'll have a E8500, 4GB ram, a couple of opticals, a 300GB HD, a X-fi Gamer and (at present) a 4850. I'd like to upgrade the VGA to a 4870 eventually and would like a new HD - would the 450 watt psu cope do you think or is that pushing it?
I know these things can run quite hot and I don't want a noisy system so maybe I'm barking up the wrong tree but I like the flexibility of this.
I dont have that particular model but I have owned many shuttles so can answer a few of your questions.
1. there is only two slots (2x pci-e with sx48 I believe) so you will have to choose your components carefully. If you get a dual slot gfx card you wont be able to put a x-fi in it.
2. There is only room for 1 optical drive.
3. These are difficult boxes to get quiet! the PSU is reportedly noisy. Most people change the fans out especially if its on your desk.
4 The PSU should cope with a 4870 fine, they work really well considering their low rating. I had a Q6600 and a 8800gt in a 250w shuttle
Actually pondering upgrading from my SD37P2 to one of these at Xmas.
They are good machines but have limitations.
One optical drive is plenty for me and I have squeezed 2 GFX cards in mine but will be replacing both for just the one new one shortly.
The on board sound is OK for general use IMHO.
