Shuttle XPC Tools (64 bit)
10 Oct 2003
Wiltshire
Hi
I’ve just reformatted my little old Shuttle SG33G5M and put Windows 10 64 bit on it, and need to try and get XPC Tools from somewhere so I can control the VFD on the front.
Can’t find it anywhere and the Shuttle download links for it are 404
I think 1.7.3 was the last version?
Thanks in advance.
Will give that a blast, thanks.
I tried installing the 32 bit version but it didn’t want to work. It installed but wouldn’t start, complaining that it wasn’t installed properly or something.
To be honest if I could get something that could control the VFD in front, that would suffice I think.
I think so, although I’ve not tested it fully. I think the VFD driver is for monitoring when Windows Media Centre (not even sure that’s a thing nowadays) is running, to shows media info.
I’ve reached out to Shuttle via email to see if they have a 64 bit copy of XPC Tools anywhere. Hopefully they’ll respond.
Thanks very much for your assistance. Have a great weekend :)
Good day there, i have the same model as the one you have. Just recently rebuild it and works beautifully. i upgraded the cpu, put in a GPU and maxed out the ram, but i bumped into some issues where my vfd display is not displaying anything other than "Home theater" is there an XPC tool for linux mint? as i don't run windows on that machine.
I finally got the display to work as it should yesterday by installing windows Vista "32 bit" since i have nothing to work on for linux mint, i was wondering if any of you have the latest XPC tool 32 bit version laying around that you could share. i downloaded the one you guys posted here, but it doesn't work. Thanks
