SI-120 HS - Fan mounting question
18 Oct 2002
Leamington Spa / Oxford
I'm looking at the SI-120 to have silent cooling of my 3500+.
I'll probably punt for an AcoustiFan: DustPROOF 120mm as they seem to be the most silent (15dB pushing 41cfm). However, how do you attach it to the heatsink? Does the SI-120 have fan mounting holes? :confused:
Above post is correct. The cooler attaches to the fan with wire clips that locate in the fan mounting holes. At worst you may have to remove some plastic from the fan sourround to allow the clip to locate correctly.
If you can post a pic of your intended fan we may be able to find out.
Matt
