** SIBERIA V3 & ELITE PRISM FINALLY HERE **
rjk
rjk
Caporegime
8 Aug 2007
Hi Guys
due to immense worldwide demand on these and the fact that the nordics have been buying these like crazy, the Siberia V3 has been delayed loads.
we now have loads of stock. so yeah... get cracking :)
SteelSeries Siberia V3 - White @ £79.99 inc VAT
The SteelSeries Siberia v3 features a newly-refined design that is both flexible and durable while still offering the legendary comfort of the Siberia series. The iconic Siberia suspension headband returns offering enduring, lightweight comfort for hours of gaming. Powerful, next-gen SteelSeries speaker drivers deliver rich, detailed sound for enhanced gameplay. Noise reducing memory foam ear cushions aid in isolating the natural sounds and powerful bass while keeping out outside noise. A retractable, flexible crystal-clear microphone can be muted with the flip of a switch behind the earcup. A PC adapter and a universal 3.5mm plug means Siberia v3 plays nice on nearly all gaming systems and devices.
- Refined acoustic space, clear details and an accurate soundscape thanks to redesigned internals
- Natural sound and powerful bass thanks to next-generation SteelSeries speaker drivers
- Comfortable and lightweight self-adjusting headband
- Noise reducing memory foam ear cushions
- Crystal-clear microphone is flexible and can be hidden away in the earcup
- Universal 3.5mm plug and included PC extension cable for multiplatform compatibility
- Supports PC, mobile devices, PS4, Mac, and more
- Microphone mute switch on the back of the left earcup
- New flexible and durable reinforced design
- Cable is twice as durable than previous models
Specifications:-
- Cable Length 1.2
- Cable Length 4
- Documentation Type Quick Start Guide
- Dismantle for Travel No
- Headphone Frequency Response (Hz) 20-20,000
- Magnet Type Neodymium
- Headphone Sensitivity 80
- Headphone Total Harmonic Distortion 1
- Microphone Frequency Response (Hz) 100-10,000
- Microphone Pickup Pattern Unidirectional (directional)
- Microphone Sensitivity -42
- Microphone Impedance 2200
- Headphone Impedance 35
- Illumination No
- Profiles Available No
- Finish Glossy / Matte
- Driver Size 50
- Microphone Location Retractable
- Microphone Noise Cancellation No
- Foldable No
- Console Compatibility PS4
- Firmware Upgradable No
- SSE Compatibility None
- Onboard Memory for Profile Saving No
- Cover Material Plastic
- Gold Plated Connector Yes
- Cable Material Rubber
- Carrying Case No
- Extended Cable Included Yes
- Controls Mute only
- Audio Channels Stereo
- Interchangeable Ear Cup No
- Headband Type Suspension
Only £79.99 inc VAT.
ORDER NOW
SteelSeries Siberia V3 - Black @ £79.99 inc VAT
Specifications:-
- Cable Length 1.2
- Cable Length 4
- Illumination No
- Driver Size 50
- Foldable No
- Carrying Case No
ORDER NOW
SteelSeries Siberia Elite Prism - White @ £129.95 inc VAT
The SteelSeries Elite Prism headset radiates with 16.8 million illuminated colors while delivering the superior sound and the comfortable design of the iconic Siberia line. Customize the illumination within SteelSeries Engine 3, including the colors, brightness and various effects (Trigger, Breathing, ColorShift).
Dolby® virtual 7.1 surround sound and next-generation SteelSeries speaker drivers offer an incredibly rich in-game soundscape for the ultimate gaming experience.
The classic Siberia self-adjusting suspension design has been refined and paired with large-opening, memory-foam ear cushions to stay comfortable through the longest of gaming sessions. Newly-optimized retractable microphone actively cancels background noise for crystal-clear transmission.
Features:
- Next-generation SteelSeries speaker drivers with dual neodymium magnets deliver rich sound and low-frequency power
- Dolby Headphone® and Dolby Pro Logic IIx® surround sound technologies for up to a virtual 7.1-channel immersive audio experience
- Noise-isolating, closed-back earcups designed for outstanding accuracy, clarity, and detail
- New retractable unidirectional microphone for incredible clarity
- Customize the illuminated earcups with 16.8 million colors
- Select among customized lighting effects including Breathing, ColorShift, and Trigger
- Advanced audio customization including 10-band EQ, mic volume control, auto mic gain, and custom sidetone within SteelSeries Engine 3 configuration software
- Backup your settings through CloudSync™ and have them saved wherever you play
- Perfect-fit suspension design provides a self-adjusting, durable structure and a lightweight, comfortable experience
- New, larger memory-foam ear cushions and relaxed headband for long wearing comfort
- Award-winning Siberia suspension design
- Flat, soft, tangle-free cable with cable ends for PC, Mac, PS4, mobile devices, and more
- Volume and mic mute controls on earcups
- Sound Share port enables you to connect to a second headset and share your sound
Specification:
- Frequency: 16-28 KHz
- Impedance: 32 Ohm
- SPL@ 1KHz, 1V rms: 113 dB
- Mic pattern: Unidirectional
- Frequency: 75 – 16000 Hz
- Impedance: <2.2K Ohm
- Sensitivity: -38 dB
- Cable Length: 1.2 meters
- Extension cable: 2 meters
- Connectors: 3.5 mm 4-pole & 3-pole x2
Only £129.95 inc VAT.
ORDER NOW
SteelSeries Siberia Elite Prism - Black @ £129.95 inc VAT
Features:
Specification:
- Impedance: 32 Ohm
ORDER NOW
I'll never buy Steelseries again, cheapest made in China products ever - build quality is pathetic.
I've had mice, headsets and keyboards from them over the years and they break randomly and without warning. Even had a software update brick a previous keyboard.
If people actually want to care about proper sound, good build quality and warranty that works, Sennheiser is where it's at.
Hi
Previously, I would possibly agree to some extent.
The Siberia headsets were a bit on the plasticy side and sound quality left a lot to be desired.
Their mice were alright really. perhaps on par with zowie in terms of quality and the lower end keyboards were fairly poor imho.
These however, are NEW headsets which are part of an entirely NEW product range being rolled out over the next six months.
I have a Siberia V2 on my head right now [its my work headset] and it has lasted two years of being worn 5 days a week, thrown about, having the cables yanked and ran over with my chair. I can think of equipment from other 'more premium' brands that wouldn't stand up to that sort of treatment so well.
regardless, the V3 I have got my hands on is far, far better built than the V2. its improved in nearly every way. the finish is far superior and it just feels a bit more premium in terms of build quality.
The sound quality isn't exactly audiophile level but its a gaming headset and there will always be people who want that.
Their mice range has been based firmly around the Rival recently. This is a smart move. Pro players sponsored by other major gaming brands risk their sponsorship deals by publicly using the Rival.
It is one of the most used mice in competitive counterstrike and Steelseries are making variants for other applications.
Internals, build quality and design are all massively improved over the days of the Sensei and Kana days and they were arguably one of the strongest points of the whole Steelseries range.
Keyboards, yeah agreed. if it wasn't mechanical, then it was fairly average. But if you want a high quality gaming keyboard your budget should be stretching to mechanical anyway. Their new keyboards are gonna be decent so again, old range compared to new.
I dont actually agree with your sennheiser comments though. despite me owning their latest Game ONE headset, the sound quality is decent, but it isn't worth 180% more money in my opinion.
but then again you are comparing a range of ~£200 headsets to a range of sub £100 headsets.
I've had my Steel Series v2 for about 5 years now, its moved to 4 different houses with me, it's had A LOT of use, I now use it on my ps4 with an adaptor along side my PC. Its been sat on, ran over by my chair and left all over the place and it still works fine.
Don't forget that with the Sennheiser PC headsets (I have a PC360 G4ME), you also pay for the quality of the microphone, which is exceptional.
I've always had a soft spot for Steelseries products, I absolutely love them. Still using my Sensei since it was released and no problems. Still absolutely faultless :)
Hi, I bought the steelseries v3 black a week ago, it's super comfy, 2 times more comfy compared to my v2 which last me about 2~3 years ago.
However v3 isn't that great when comes to mic quality, my friends complaint on my new headset, they can heard themselves whenever they speak, crosstalk problems, and it has problem when I mute the button on the earcup, it basically outputs the sound from what I'm listening to my friends on teamspeak, v2 doesn't have problem like this... Kind of disappointed to be honest.
Noticed the little price bump on the v3's there. Glad I picked mine up when they were on a daily deal the other week. Great headset personally I don't see the issue with the mic I thought it was quite good.
No offence but you are talking out of your arse.
I bought the SteelSeries M800 keyboard and Rival mouse a few weeks ago and the build quality of both is SUPERB.
I am super happy with my purchase. I shall be buying the Elite Prism in black tomorrow to complement.
