Sick Beard and sabnzbd help
Man of Honour
20 Sep 2006
Not sure this is the correct section so apologies if not.
What I am trying to achieve is the following:
Download to D:\Downloads\
Incompletes in D:\Downloads\Incomplete\
Post process including rename to D:\Post processed\
(renamed slightly :p)
Current settings:
It creates all the sub folders fine in the post process folder but doesn't seem to move it all automatically once downloaded, I have to initiate a manual post process.
Any ideas?
Sab is running the sabToSickbeard.exe file for each download?
Sickbeard finds the files and tells Sab to go fetch. Sab will then get them and put them in the complete folder. Only if they are then told to run the sabToSickbeard.exe will sickbeard go find them on your drive and move them and update its database.
Doesn't seem to be working at all. There's loads of completed downloads in the downloads folder but they're not moving to the end folder.
