Sickrage / Sickbeard question
Caporegime
24 Oct 2012
Godalming
Morning :)
Having finally started getting my media server running as I want it to, I'm using Sickrage to get all the stuff I want.
Now when I add a new show, it snatches most of the current episodes, but skips a lot too, these stay as "wanted". If i click on the magnifying glass, it'll find them and add them, but it won't do it automatically.
I've checked all the options and from what I can tell, it *should* just go ahead. with it. There is also no sequence to which ones it skips, it seems to be completely random.
It's not a big thing, as I can click all the mag. glasses myself and do it manually but having come this far with automating everything, it's that last little niggle which is stopping this from being a perfect system.
Any way I can find out why it's doing this?
Cheers!
Sickbeard does this for me too, sometimes it's awesome. Sometimes it just doesn't work, also puts shows to 'unaired' which means it doesn't even look for it untill you refresh it.
I can see this thread being deleted though.
