- 2 Oct 2007
- Oxfordshire
Right, getting the following issue whenever I try and load lots of programs (iTunes, Spotify, Word, VS2008 etc etc):
Had a quick look around the internet and they said to look at event viewer. Every time I try to load a program I have this message in event viewer:
Now, I have one of those Patriot PS-100 SSD's (kept it in the end after firmware update FINALLY) seemed to fix it. Could that be dying? Is it a Windows Update (I had just installed an optional one for windows 7 x64, something about being compatible with some sort of drive about 32gb (can't quite remember all of it) Any ideas on how to solve this issue without a whole reformat??
'The application has failed to start because its side-by-side configuration is incorrect.'
Activation context generation failed for "System Default Context". Error in manifest or policy file "C:\Windows\WinSxS\manifests\x86_microsoft.windows.c..-controls.resources_6595b64144ccf1df_5.82.7600.16385_en-us020378a8991bbcc2.manifest" on line 0. Invalid Xml Syntax"
