I have a 80mm side case fan that draws air in and blows onto the area where my CPU is. The fan came with the case, is quite noisy, and as it's a generic brand I'm not that convinced it's doing as good a job as a decent quality fan would.
I was going to buy an Akasa Amber fan as I already have two of these drawing air out of the back of my case and I know they do remove a lot of air and are relatively quiet.
It occurred to my though that I could buy a 80mm to 120mm converter and install a 120mm Akasa Amber which would be even quieter and blow more air into my case, but would it be worth the extra expense; i.e.would it improve the cooling of my CPU? Might it also help to keep my motherboard components cooler?
If anyone has any experience with side case fans and if they're effective, I'd be grateful for your advice.
Cheers, dagwoood.
Cheers, dagwoood.
