Side cooling haf 932
17 Nov 2011
Birmingham
Just a noobish question, but i currently have the stock 230mm side fan on my haf 932. The side of this case has a lot of holes so the dust is easily sucked in, therefore i currently i have a filter over it. But that reduces the airflow by a lot, is there any sort of fans that would work effectly with a filter over them or are they all restricted.
would it be worth replacing that 230mm fan? they can be expensive
have you tried a different fan filter?
a piece cut out from a pair of ladies tights stretched over the fan works well, so go for a thin deneir (i think thats what its called ;))
And this magical material doesn't restrict the airflow that much either! Just don't blame us if the person at the till gives you wierd looks for buying one...
lol
How do you know so much?
