Side Fans
Permabanned
28 Dec 2007
Hi,
Just built my new system from the parts i got from OCUK today. Part of the stuff was a Coolermaster 3Storm case and i bought 2 akasa 120mm side fans for it. Ive built it all up and its soooooooooo fast but the side fans are on full it seems and they are very very loud. I cant put up woth this racket its that loud. Am i doing something wrong?
Matt
Use the above fan controller in my system :)
You can install the fans onto the motherboards fan header but you will need to check if you have control over these.
