side panel fan intake or outtake
23 Nov 2009
North Leicestershire
What do you have on g-cards that dump hot air into the case i'm looking at ideas for more efficient cooling etc etc
been also dabling with the idea of sectioning off the top hlf of my case/mobo so it's compartmented so hot air from the gpus is expelled before it gets a chance to hit my NH-D14 cou cooler.
Throw me your ideas :)
TESTING RESULTS ARE NOW IN PLEASE CHECK OUT POST 12
Intake, as it blows cool air onto the fan of your GPU which then blows the cool air acroos the heatsink. You should also have positive airflow in your case (more intake than outflow fans).
Although I have not tried it yet I think if you create positive air pressure on the inside by having more/faster filtered inlet than outlet it will solve many cooling issues.
Less strain on the GPU/exhausting fans and possibly reduce noise.
Less air coming through unfiltered sources and pulling in dust.
The case will have more fresh cool air per volume and less "used" air.
i'm on a haf x and have 2x230mm fans as intake and 1x 230 and 1x140 as out-take (positive pressure)
my side panel is intake to blow cool air onto the gpu's @Surveyor why would it being outlet help keep the cards cooler?
my side panel is intake to blow cool air onto the gpu's @surveyor why would it being outlet help keep the cards cooler?
Because it will extract the hot air being dumped by the graphics cards.
An easy one for the OP to test.
Fit the fan one way and monitor GPU temperatures.
Fit the fan the other way and monitor GPU temperatures.
Stick with whichever works best.
I am the op lol,
i'm just about to start re- painting my room so when i've done tonight i'll give some configs a go , i've got 4x spare 230 mm fans i also have a free space on top of my case for another 230mm but i could never decide whether i should have it as intake or out take so i left it off. I believe demci flex who make some of the best after market filters said positive pressure is always better as it stops unwanted dust collecting in the case and also forces hot air out of the case.
HAF-X user here too,side fan is intake too,look forward to seeing your results,i must admit that as much as i like this case,the weekly dusting to clear the vents peeves me somewhat,haha,or i'm just lazy.:D
RESULTS ARE IN
Msi kombuster 5 minute tests on gpu burn in in mode using 4xAA using manual fan set at 60%. All tests the card was allowed time to settle back to idle temp for 5 minutes.I have higlighted the most interesting results in yellow
Degrees
Ambient temp 28 c (Yes my house is roasting)
side panel fan on full intake (positive pressure)
GPU temp 64
CPU temp 42
GPU Return to idle 38c
CPU Return to idle 40c
side panel fan off (negative pressure)
GPU temp 66
CPU temp 44
GPU Return to idle temp 39
CPU Return to idle temp 40
Side panel fan outake ( negative pressure)
GPU temp 69
CPU temp 42
GPU Return to idle 39
CPU return to idle 40
Side panel fan outake with additional top fan as intake (negative pressure)
GPU temp 69
CPU temp 41
GPU return to idle 39
CPU return to idle 39
Side panel fan outake with additional top fan as outake (extreme negative pressure)
GPU temp 69
CPU temp 45
GPU return to idle 40
Side panel fan intake with additional top fan as outake (Negative pressure)
GPU temp 64
CPU temp 42
Side panel fan intake with additional top fan as intake (extreme positive pressure)
GPU temp 64
CPU temp 42
Side panel off completly (equal pressure i presume)
GPU temp 67
CPU temp 43
Round-up
Interestingly despite what a lot of people say actually having the side panel fan as outake increased temps by over 7 degrees. What did seem to make sense was the whole idea of heat rising having the lower fans as intakes and upper fans as outakes seem to force the warm air out.
Look over the results yourself if anyone else has time to test this then please share your results.
I think this result only confirm that for the HAF-X it is better to have the the 200mm side-panel fan as intake rather than exhaust, but I don't think it applies as valid result for midi-cases of other models.
Just a couple of things I would like to point out:
i) For the HAF-X, the drive bays restrict airflow from front intake, so cool air simply isn't getting into a main department of the case at a effective rate, therefore not enough cool air reaching the graphic card's cooler if the side-panel was exhaust instead of intake
ii) The 200mm fan on the side-panel of the HAF-X pretty much nearly cover the full length of the graphic card, where as more midi-case only got a 120mm on the side-panel, which only roughly cover half of the graphic card's length on the left (rear) side. Also the side-panel has a shroud for channeling the air-intake to the right, so it increase the efficiency of the fan as intake, but get in the way when the fan is used as exhaust instead.
iii) Midi cases don't have the luxory of two 200mm on top as exhaust
For my CoolerMaster 690II with MSI 5850 Twin FrozRII, the differcent between having the side-panel (with a 120mm fan) as exhaust and intake was that temp was was roughly 4-5C higher on intaken than exhaust. This is with good intake and with the unneeded removable drive bays removed.
So having good default amount of air-intake or not and case layout/design would be the determining factor.
