Side panel window cleaning
12 Nov 2009
London
hey guys,
So while I was away, my gf decided to do a spot of cleaning, but in the process she cleaned my pc side panel with I assume was just some water and a cloth...
So now my sidepanel has those nasty water streaks all over it and its doing my nut in lol.
Can anyone suggest the best way to clean my sidepanel and get rid of these streaks?
Proper glass cleaner and a microfibre cloth. If you dont have a microfiber cloth then kitchen roll can be used, anything super absorbent. But a microfiber cloth is the best thing to use as it's a lot less likely to put little circular scratch marks into the plastic.
