Side Window Kit for Arc Mini
2 Jul 2012
Berkshire, UK
So I really want to put a Side Window on a Fractal Design Arc Mini.
I'm not really too sure about doing it myself, but if anyone could suggest a list of the bits I would need in order to do it my self, that would be good. (I want it to look like the side window on the Corsair 600t).
Also if I could get a replacement side panel, or a kit with all of the bits in that would be great!
Thanks :cool:
dremel + cutting bits
perspex/choice of window material.
screws/glue
balls.
that should sort you
LOL, straight to the point!
BTW, when you say screws, this is if you were to screw in the perspex panel as opposed to glueing it down, correct? What screws are recommended if screwing down?
Thanks.
well, when I did my side window on my case I used window rubber moulding to clean the window edge up a bit, then used strips of double-sided tape to stick the perspex to the moulding. Worked great and you don't see a shred of tape :)
Hope so.
I sent an e-mail to Fractal Design and they said that they have "none in production but we may consider making one in the future depending on how the R3 windows are received".
Thanks for the Info , i sent off 2 emails from 2011 to now to Fractal Design
they said both R3 & arc midi cases, i guess i have to change case , watercooling set up no good without window.
What about those of us with a windowed case but no watercooling? :p
