Hi, I have just finnished cutting the side window in my case panel I have taken off all the burrs and when the wet and dry gets here I am going to rub it down and make it smooth befor a respray.
My question is what do I put on the metal edges, or what do I need to do to the cut out before I put the perspex in place also what size 2m or 4mm which will be glued in place, on the out side of the panel should I line the edges with anything and if so what ?Any help really appreciated as this is my first case mod, Thanks for any help given.
Wayne,,
Wayne,,
