Sidewinder X4 quick question
2 Aug 2011
Newbury
Can you change the colour of the backlight to Blue? I notice it shows up as red, but my PC and Mouse have Blue LED's. Just wanted to know before I order.
The Logitech G110 is pretty decent. But normally around £60. not exactly cheap.
If you can find the older G11 their good as well and will be cheapish
I spent like £90 on a Razer Keyboard last year and it was faulty, RMA and then went faulty again. So I'll avoid their Keyboards. Still using a Razer Mouse though. I'll check out the G110
Changing the backlight color on an X4...
This question comes up so frequently, I wrote an Instructable on how to do it.
http://www.instructables.com/id/Change-the-Backlighting-Color-on-a-SideWinder-X4-K/
Presuming you know how to solder, this takes about 15 minutes...
Note: This is not endorsed by Microsoft, and it will certainly void your warranty.
