Sidewinder X6 Keyboard
There aren't that many about with detachable numpads. I would recommend the X4 or Logitech G110 as replacements. Or if you are feeling rich the Qpad MK-80 or MK-85.
Not too bothered about that, I'm mainly after a replacement for my aging v1 G15.
Ideally I want shallow keys (shallower the better), a volume control on a wheel (quicker than on buttons), media keys, and macro keys. I saw an X6 round a friend's and realised it had what a needed and looked great too. Can't find one anywhere though.
The G110 has the volume wheel but the X4 has the slimmer keys. Both have macro keys and media keys. The X4 has a slightly different key spacing than most keyboards. It was a deal breaker for me but for most it isn't a problem.
I would go for the G110 personally.
X6 is terrible, I have to take mine apart every month because the Silicon thing underneath the keys keeps slipping down and certain key combinations can't be pressed as well cause it doesn't register the keys being input [which is bad for mmo's].
Worst £30 I spent, if those 2 problems weren't present then it'd be worth it.
