- 2 Jun 2004
since when did anyone read mails sent to [email protected] anyway? i've never had a reply to any queries i've sent to that address.
lolnumber41 said:The email says forum, not forumsMaybe you've been emailing the wrong address
seek said:lol
'twas a typo! but seriously, in my experience you don't stand a chance of getting an answer unless you get a staff members personal email address.
lolStellios said:I cant be othered to change it now, took me a while to make the sig they removed.
OT: Are you the Stellios who owns easyJet?Stellios said:I cant be othered to change it now, took me a while to make the sig they removed.
the Key here being "if no image is used"the FAQ said:A signature may contain one or more images but they must fit within a box with maximum dimensions of 400 x 75 pixels (width x height) and with a maximum (combined) file size of 20k. Images containing mostly very large words or animated .gifs will not be permitted. You may also add 1 consecutive lines of normal or smaller text directly above or underneath the image with no spaces inbetween image and text. If no images are used then up to 4 consecutive lines of normal or smaller text is permitted.
Aod said:wasn't there controversy a while ago when basmics sig image had more than 4 lines of text in it, and you mods forced him to change it to four, even though the rules only state this:
isn't that a little hypocritical seeing as this sig that you give people with incorrect sigs has 5 lines of text?
Nope, it's because some people decided to use images to cram their signatures full of text that would otherwise not fit. To demonstrate that point...Aod said:isn't that a little hypocritical seeing as this sig that you give people with incorrect sigs has 5 lines of text?
silversurfer said:Thats definetly one of the weirder rules, hard to see a point to it
