<?php
$folder = '';
$exts = 'jpg jpeg png gif';
$files = array(); $i = -1;
if ('' == $folder) $folder = './';
$handle = opendir($folder);
$exts = explode(' ', $exts);
while (false !== ($file = readdir($handle))) {
foreach($exts as $ext) {
if (preg_match('/\.'.$ext.'$/i', $file, $test)) {
$files[] = $file;
++$i;
closedir($handle);
mt_srand((double)microtime()*1000000);
$rand = mt_rand(0, $i);
header('Location: '.$folder.$files[$rand]);
Whose that built by, thanks
If you have your own webhosting the you can rotate on any forum using a rotate.php file.
Code:<?php $folder = ''; $exts = 'jpg jpeg png gif'; $files = array(); $i = -1; if ('' == $folder) $folder = './'; $handle = opendir($folder); $exts = explode(' ', $exts); while (false !== ($file = readdir($handle))) { foreach($exts as $ext) { if (preg_match('/\.'.$ext.'$/i', $file, $test)) { $files[] = $file; ++$i; } } } closedir($handle); mt_srand((double)microtime()*1000000); $rand = mt_rand(0, $i); header('Location: '.$folder.$files[$rand]); ?>
Then just put your image files along with that as rotate.php in your folder on your web space and link to rotate.php as an image.
Easy...
$images = glob("{*.jpg,*.JPG,*.jpeg,*.JPEG,*.png,*.PNG}", GLOB_BRACE);
readfile($images[array_rand($images)]);
I can see you take that advice to heart... awesome set of sigs SkyfallMake sure you've got some good sigs to rotate.
Or you could do it in a couple of lines:
PHP:$images = glob("{*.jpg,*.JPG,*.jpeg,*.JPEG,*.png,*.PNG}", GLOB_BRACE); readfile($images[array_rand($images)]);
Massive thread bump because I've built one of these.If you have your own webhosting the you can rotate on any forum using a rotate.php file.
<?php
declare(strict_types=1);
$imageDir = __DIR__ . '/sigs';
$stateFile = __DIR__ . '/sig_last.txt';
$allowedExt = ['jpg', 'jpeg', 'png', 'gif', 'webp'];
$files = [];
foreach ($allowedExt as $ext) {
foreach (glob($imageDir . '/*.' . $ext) as $path) {
if (is_file($path) && is_readable($path)) {
$files[] = $path;
if (!$files) {
http_response_code(404);
header('Content-Type: text/plain; charset=UTF-8');
echo "No signature images found in {$imageDir}.";
exit;
$choice = $files[random_int(0, count($files) - 1)];
$fp = @fopen($stateFile, 'c+');
if ($fp && flock($fp, LOCK_EX)) {
rewind($fp);
$last = trim((string)stream_get_contents($fp));
if (count($files) > 1 && $last !== '') {
$pool = [];
foreach ($files as $path) {
if (basename($path) !== $last) {
$pool[] = $path;
if ($pool) {
$choice = $pool[random_int(0, count($pool) - 1)];
ftruncate($fp, 0);
rewind($fp);
fwrite($fp, basename($choice) . "\n");
fflush($fp);
flock($fp, LOCK_UN);
fclose($fp);
} elseif ($fp) {
fclose($fp);
$mime = 'application/octet-stream';
if (function_exists('finfo_open')) {
$finfo = finfo_open(FILEINFO_MIME_TYPE);
if ($finfo) {
$detected = finfo_file($finfo, $choice);
if (is_string($detected) && $detected !== '') {
$mime = $detected;
finfo_close($finfo);
header('Content-Type: ' . $mime);
header('Cache-Control: no-store, no-cache, must-revalidate, max-age=0');
header('Cache-Control: post-check=0, pre-check=0', false);
header('Pragma: no-cache');
header('Expires: 0');
header('X-Sig-Nonce: ' . bin2hex(random_bytes(8)));
$size = filesize($choice);
if ($size !== false) {
header('Content-Length: ' . $size);
if ($_SERVER['REQUEST_METHOD'] === 'HEAD') {
exit;
readfile($choice);
