Sig Sizes Changed?
15 Nov 2005
Peterborough
Have the rules changed about sig sizes?
Uptil a couple of hours ago, my sig was fine and now I have the lovely yellow message saying it is too large! (I have had the sig for at least 6 months or more)
20kb max.
It maybe having more than 4 lines of text in the sig.
EDIT : you should really ask the mods. Click on the warning triangle and ask , you are not allowed to question a decision on the forum.
Mark
mrdbristol said:
20kb max.
Mark
Yeah, I should really, just wondered if something had changed since about 4pm this afternoon!
I only had one line of text.
Ah well, I will just have to design a fresh siggie.
:confused:
The triangle is used to Report a Post to a moderator. Wouldn't it be easier to email a Don and ask?
iCraig said:
:confused:
Yes , that would have been the correct route.
Thank you for your correction.
Mark
Post the image here and we'll tell you what's wrong with it. If it's just filesize, someone will inevitably save it with half the filesize for you :)
