Sigma 70-300mm ???? EF mount or EF-S???
13 Jun 2008
hi all
does anybody own the following lense ?
Sigma 70-300mm f/4-5.6 APO DG Macro -
Product MPN 504110
UPC 085126504403
and if so will it fit on my canon 10D ?
i have looked on the sigma website with no luck :confused:
the gentleman selling says it is a canon fit but knows no more than that
thank you for any help it is much appreciated....
It will fit, DG is full frame, DC for APS-C. Even if it was DC it would still fit as third party APS-C lenses do not intrude into the body as far as EF-S lenses.
I googled 'MPN 504110' & 'sigma MPN 504110'
The sites I found seem to imply that this particular lens is for SIGMA SA mount!
One of the sites has the same UPC number.
