Sigma Circular Polarisers
12 Jan 2004
Londinium
Okay, thought I should pick up a half decent polariser for my Olympus e500 (+ 2 kit lenses) and was looking at the Sigma 58mm Circular Polariser. Has anyone had any experience with these filters? Are they recommended?
nero120 said:
The Hoya 58mm is £74.99 and the Sigma is £49.99. I always thought Sigma was a respectable make and at this point £25 means I get to eat tonite! ;)
What the? The Hoya 58mm circular polarizer is £30 tops.
The one on the site I am buying my other gear is the Hoya 58mm PRO-1D Circular Polariser Filter, that's why its more expensive. The sigma one is the Sigma 58mm Wide Multi-Coated Circular Polarizing filter.
Would the Sigma be good enough do you think?
Hell, the £30 is fine. Don't buy the super pro model. Just a normal Hoya will be fine.
I've just bought a 77m Hoya Pro1 Polarizer and whilst it's expensive (£130) everyone says it's worth it. Also, all of my 3 lenses have 77mm threads so I don't need to buy any more in different sizes \o/
Whats the diffrence in the normal ones and the Pro type?
http://www.hoyafilter.com/products/hoya/pro1d-01.html
Hoya Pro1 Digital Filter Series
Digital Multi-Coated
Digital multi-coated filters greatly reduce the appearance of lens flare and ghosting caused by reflections.
Black Almite Frame
Filters feature a black matte
aluminum satin finish almite frame which reduces reflections.
Black Rimmed Glass
These filters are equipped with black rimmed glass to reduce the chance of light reflecting off the edge.
Low Profile Frame
Ultra thin filter frames to help avoid vignetting on super wide angle lenses are also designed to hold a lens cap.
Knurling Edge Frame
These filters are equipped with a straight knurling edge for non-slip, easy attachment and removal.
UV Protected Case
Filter cases are UV protected to further lengthen the life of filters.
