I bought a Phillex SLX1 1 way signal booster to help me get freeview. I currently have the roof aerial plugged into a sky box, the output of this is split into 4 and goes into rooms around the house and my room (long cables).
I plugged a short wire from the booster (output) to the TV in my room and plugged the long cable into the booster (input).
When using the booster I am getting a rubbish signal, all the terrestrial channels are worse and i'm not getting a signal at all on freeview.
Without the booster the terrestrial channels are fine and I get a low signal on freeview.
There is a gain control on the booster, when I change this nothing changes to the picture on the screen, the picture is full of static and the sound is crackly.
Does this sound like a broken signal booster or have I done something wrong?
Thanks
Thanks
