Signal rgb
19 Mar 2011
So i do have some rgb in my pc and have been using the stock apps/utils to control it all icue aura etc and have never been able to get it all to sync very well until now
after finding signalrgb free version.
if i stick to srgb can i safely remove all the other bloat ware rgb apps?
thanks
I used to use it for controlling a mix of Asus and Corsair hardware - worked brilliantly with zero other software running.
Pay attention to the update/refresh rate. If it's set to a low (fast) value your CPU usage can get surprisingly high.
