17 May 2020 at 17:36 #1 Th3D0n Th3D0n Associate Joined 3 Jul 2007 Posts 1,976 Location Rochdale/whitworth can some one help resize my Signature its file size is to big for here would it be passable to do it without it changing
17 May 2020 at 18:29 #2 Vince Vince Man of Honour Joined 30 Oct 2003 Posts 14,389 Location Essex Slight reduction in quality but I did use gimp so what can you do?
17 May 2020 at 18:44 #3 Deleted member 77746 Deleted member 77746 Permabanned Joined 9 Aug 2008 Posts 35,717 Compressed, Slight Colour loss. 9.82KB 69% SQUISH.
17 May 2020 at 19:08 #4 Th3D0n Th3D0n Associate OP Joined 3 Jul 2007 Posts 1,976 Location Rochdale/whitworth mrbell1984 said: Compressed, Slight Colour loss. 9.82KB 69% SQUISH. Click to expand... thats perfect pal thank you Vince said: Slight reduction in quality but I did use gimp so what can you do? Click to expand... both good i cant see the defence
17 May 2020 at 19:23 #5 Deleted member 77746 Deleted member 77746 Permabanned Joined 9 Aug 2008 Posts 35,717 Th3D0n said: both good i cant see the defence Click to expand... Make sure you use your karate skills correctly.
17 May 2020 at 20:23 #6 Th3D0n Th3D0n Associate OP Joined 3 Jul 2007 Posts 1,976 Location Rochdale/whitworth mrbell1984 said: Make sure you use your karate skills correctly. Click to expand... haha ok. both good i cant see the difference
