- 26 Jun 2005
My 2006 1.6Tdci Focus has been in to my local garage for a failed alternator and while in I had a service & MOT. They tested the battery & said it was fine so didn't replace it. Two days after it came back it wouldn't start, so I jump started it from my wife's car. It started fine and ran for about 2min & then sounded weird so glanced at the engine fit was rocking back and forth like it was only on 2 or 3 cylinders.
I quickly switched it off & called the garage. Nothing worked, central locking, etc. Anyway, they said the Alternator had failed so replaced it & the battery this time.
I got it back on Friday & have just been out on a longish drive & its not right.
Firstly there's no power delivery like before. It had a predictable turbo boost at certain RPM and the engine Power would drop off significantly after 2500RPM. So most of the driving was done well under this. Now I'm having to rev well into 2500 RPM to get any power at all..I used to be able to hear the turbo whine at certain seeps too. This has gone too. There's a new sound at about 2200RPM like a stiff bearing or slipping belt. I hope it's the alternator and not the Turbo.
Another issues post repair, if I'm cruising at 30-40Mph in 3rd gear say, the engines at 1750RPM, it cuts out every few seconds for a split second. It's like taking your foot off the pedal and back on again. It's predictable and happens every time for as long as the car is at those revs.
So, any pointers on what it could be? It's going to another garage on Tuesday.
... I think I was just going on the proviso that a fully charged battery in open circuit would be a maximum of 12.6v so just said "above this"
